Samsung SCH-A670 Camera Replacement
    1. Samsung SCH-A670 Camera Replacement, Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the latch on the back of the phone up.
    2. Samsung SCH-A670 Camera Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery.
    1. Samsung SCH-A670 Camera Replacement, Logic Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
    2. Samsung SCH-A670 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
    3. Samsung SCH-A670 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a #0 Phillips screwdriver remove the screw which you just uncovered.
    4. Samsung SCH-A670 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-A670 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
      • Then disconnect the small power connector near the top of the phone.
    5. Samsung SCH-A670 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry up the ribbon-type connector with the spudger.
    6. Samsung SCH-A670 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry the logic board from the case with the spudger.
    1. Samsung SCH-A670 Camera Replacement, Keypad: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the logic board has been removed, peel the keypad up.
    1. Samsung SCH-A670 Camera Replacement, Keypad Housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung SCH-A670 Camera Replacement, Keypad Housing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
    1. Samsung SCH-A670 Camera Replacement, Screen Casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove screws with #0 Phillips screwdriver.
    2. Samsung SCH-A670 Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry apart the casing with the spudger tool.
    1. Samsung SCH-A670 Camera Replacement, Screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger to carefully pry off the speaker.
    2. Samsung SCH-A670 Camera Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry off the ringer with the spudger.
    3. Samsung SCH-A670 Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry off the screen with the spudger.
    1. Samsung SCH-A670 Camera Replacement, Camera: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry off the camera with the spudger.
Nathan Brink
crwdns2935283:004/11/10crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-59, Forte Spring 2010 crwdns2935289:0Cal Poly, Team 34-59, Forte Spring 2010crwdne2935289:0
CPSU-FORTE-S10S34G59
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,502
