Samsung SCH-3500 has an easy to replace antenna in the upper right hand corner that will probably wear out over a long period of time. These replacement antennas can be found online and can be shipped right to your door. A new one will be the only part you will need for this guide on replacing an antenna on a Samsung SCH-3500. No other external tools required to do replacement. Pictures of individual steps provided with further details listed beside.
Place the phone so that the back is facing you. Depress the locking tab on the back of the phone with a finger or thumb.
Slide the battery toward bottom of the phone, about a quarter of an inch, to clear the hooks that keep it secured to the back of the phone.
Lift the battery away from the phone case.
Grasp the antenna firmly and rotate it counterclockwise to unscrew it from the phone.
When unscrewed, pull the antenna straight up and out.
Pull the guide tube free from its retaining ring and slide it out the top.
