When you use your camcorder to record video, you’ll find that the hand strap is one of the most useful components to stabilize your image/video. The hand strap in your device is likely to wear out and become unusable. If you’re looking to replace a worn out or damaged hand strap, follow the steps in this guide.
Remove all eight screws using the Phillips #000 screwdriver.
Pull apart the sides of the camera once the screws are removed.
Remove the three screws using the Phillips #000 screwdriver.
Remove the four screws using a Phillips #000 screwdriver.
Remove the hand strap from the device.
