Samsung Rogue Motherboard Replacement
  1. Samsung Rogue Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Rogue Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Motherboard Replacement, Speaker/Antenna: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
  11. Samsung Rogue Motherboard Replacement, Camera: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement, Camera: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Rogue Motherboard Replacement, Camera: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With two fingers carefully detach the camera from the motherboard by lifting straight up.
    • Do not pick it up by the camera itself. Handle the little black box it is attached to instead.
  12. Samsung Rogue Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Rogue Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to take the silver plate off of the motherboard.
Blaine Nesbit
crwdns2935283:004/15/12crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-32, Maness Spring 2012 crwdns2935289:0Cal Poly, Team 7-32, Maness Spring 2012crwdne2935289:0
CPSU-MANESS-S12S7G32
crwdns2935297:020crwdne2935297:0
crwdns2942667:0crwdne2942667:0 841
