Samsung RC512 HDD Replacement
crwdns2942287:0crwdne2942287:0HDD may need to be replaced if it is damaged or not working properly. Also upgrading to Solid State Drive (SSD) or a bigger capacity of HDD requires this replacement guide.
crwdns2944105:0crwdne2944105:0
Place the laptop upside down.
Locate two notches above the battery.
Slide both battery locking notches to either side to remove the battery.
Pull the battery out.
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Carefully lift the HDD up using plastic opening tool.
Take out the HDD and leave the connector in the laptop
