This guide will teach you how to replace the battery of your POWERbot. This can be done to fix your POWERbot's charge retention issues.
Turn off the emergency switch located at the bottom right of the POWERbot.
Unscrew the two 6mm Phillips #1 screws and remove the lid, exposing the battery.
Follow the wires and find the small white box next to the battery.
On the side of the white box facing the battery, find the rigid tab.
Push the tab inwards to the white box and pull the wires up. This will release the wires from the white box, allowing you to remove the battery.
Remove the battery by holding the battery in place and partially righting the POWERbot so the battery falls out.
