Acquire better quality of cleaning from your POWERbot with a clean brush. This can resolve the C 01 error code. The POWERbot's emergency switch should be turned off before handling the device.
Flip the device over to access the bottom of the vacuum with the brush compartment positioned close to you.
Slide up on the two yellow sliding tabs to unlock the brush compartment.
Press down on the outer edge of the brush cover to tilt the brush cover up. Grab the newly exposed inner edge and lift out the brush cover.
Pull up the left side of the brush and lift out of the brush compartment.
Anyone know where I can actually buy a brush seems to be out of stock everywhere?
crwdns2947412:05crwdne2947412:0
How often should the power VR 7000 series self cleaning powerbrush be replace?
Hello, where could I find a replacement brush for this model?
Without a part number, I cannot find a replacement brush.
Your brush motor is broken and you can't find it?
engine model: RS395 - 2175 metal case,
Hi, Can anyone send me some info on a part number and where to get a replacement brush ~ Samsung POWERbot R7070 Power Brush Replacement?
Thanks much
