Samsung POWERbot R7070 Left Driving Wheel Replacement
  1. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement, Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
  14. Samsung POWERbot R7070 Left Driving Wheel  Replacement, Left Driving Wheel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement, Left Driving Wheel: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws securing the left and right ends of the wheel casing to the base of the vacuum.
  15. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screws securing the black plastic piece to the left of the wheel casing.
    • This piece is not part of the wheel casing but must be moved out of the way to remove the wheel.
    • Lift the wheel casing out of the vacuum base.
  16. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Arrange the wheel so that the spring is fully retracted.
    • Unhook one edge of the spring by carefully pulling the spring towards the hook.
    • With the spring unhooked, remove the spring from the wheel casing.
  17. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws that are fastening the two halves of the wheel casing together.
  18. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open wheel casing.
  19. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the black 1 cm screw securing the center of the wheel to the remaining half of the wheel casing.
  20. Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung POWERbot R7070 Left Driving Wheel  Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wheel.
crwdns2935229:05crwdne2935229:0
Eric Anderson
crwdns2935283:009/11/17crwdne2935283:0
465 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G8, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S2-G8, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S2G8
Where can you find the replacement left driving wheel? are all the model the same?
ghvolleyball - crwdns2934203:0crwdne2934203:0
My left wheel seams to have sand in the gear box now and won’t turn. I need a replacement part or assembly for a R7065 Powerbot LH wheel gear box, which is very similar to the R7070. As far as I can see (I have one of each) the R7065 has two rubber beaters and two brush beaters where as the R7070 has 4 rubber beaters.
Steven Nicholas - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,558
