If your laptop only powers on when the power adapter is plugged in, you may have a faulty battery and it needs to be replaced. Signs of a faulty battery can include: device isn’t charging, device won’t hold a charge, device won’t turn on, etc.
This is a battery replacement guide for the Samsung Notebook 7 Spin NP740U3MK01US. Before beginning, make sure to power off your device and disconnect it from any external power source.
Flip your laptop over so that the back is face up.
Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
Use a plastic opening tool to remove the back plate from the laptop.
Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
This is a great guide. Where do I purchase the battery from as I’m not finding it on this website?
