Samsung Notebook 5 NP530E5M RAM Replacement
  1. Samsung Notebook 5 NP530E5M RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Notebook 5 NP530E5M RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the single 6.5 mm screw that secures the plastic door labeled "Memory" to the bottom case.
    • Set the screw to the side in a secure location.
  2. Samsung Notebook 5 NP530E5M RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger or opening pick under the door, and pry it open.
  3. Samsung Notebook 5 NP530E5M RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pry tool to disengage the pressure clamps holding both sides of the RAM chip.
    • Open both sides simultaneously to release the RAM module.
    • Once released, the existing RAM will pop upward.
  4. Samsung Notebook 5 NP530E5M RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gripping from the sides, gently pull the RAM from its seat.
    • Be careful not to break or bend the leads on the RAM, as this would render the unit useless.
  5. Samsung Notebook 5 NP530E5M RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Notebook 5 NP530E5M RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the new unit with the RAM slot, and insert the RAM stick at a slight angle, it will rest loosely in its seat.
    • Lightly press down on the RAM until you hear a "snap". This means that the latches have clasped shut, securing the RAM stick.
    • There are two RAM slots in the Samsung Notebook 5 NP530E5M. We recommend that you install the first RAM in the bottom slot, in case you decide to add more RAM later, you wont need to worry about removing your first stick.
    • Replace the memory door and secure the screw. Tightening the screw, but be careful not to apply to much torque, "stripping" the screw, rendering it useless.
Lucas Gil
crwdns2935283:009/07/23crwdne2935283:0
690 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-1, Gonzalez Fall 2023 crwdns2935289:0Gateway, Team 1-1, Gonzalez Fall 2023crwdne2935289:0
GCC-GONZALEZ-F23S1G1
crwdns2942667:0crwdne2942667:0 366
