A commented How To to disassamble the Samsung NaviBot SR8981 (VCR8981L3B-XEG) to its parts.
The How To in the Answer of szantaiimre on the following page helped me a lot, whith slight adjustments (same Manufacturer, other Modell, but near enough)!
First, remove the dust container from the SR8981.
Screw on the battery compartment at the green marked points and open the lid.
The blue arrow marks the connection between the battery and the housing. Once this is solved, the battery can be removed from the device.
Open and remove the brush cover on the fixing clip (green arrow).
The brush can be easily lifted out of the warehouse on the right and then removed to the right.
The first picture shows the side view.
Second picture: The plastic bracket (green arrow) of the side part must be carefully levered over the plastic nose (blue arrow). Subsequently, the side part can be pulled backwards.
Third picture: The side panel has been pulled back, now the plastic bracket (green arrow) and the plastic nose (blue arrow) are clearly visible.
Loosen screws on the left (first picture) and on the right
Second picture: carefully loosen the plastic claw and pry off the cover plate.
Third picture: the NaviBot without cover plate
Remove the marked screws (green arrows) and remove the intermediate level.
To disassemble the front sensor cover, the six screws on the bottom (second picture) must be removed.
Remove the screws on the green arrows.
Release the plug connections (Fig. 2). Caution: especially the rigid cable connections (Figure 3) are a bit difficult to open and can be damaged without the proper caution.
Once the four front screws are loosened, the front tripartite sensor board can also be removed.
Follow the instructions in reverse, to reassamble the Device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
