Samsung NX500 Screen Side Encasement Replacement
  1. Samsung NX500 Screen Side Encasement Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out battery.
  4. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Screen Side Encasement Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
carter grenewicz
crwdns2935283:009/15/16crwdne2935283:0
204 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-5, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-5, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,031
