Samsung NX500 Main board  Replacement
Eli Carcalete
crwdns2944107:0crwdnd2944107:0Eli Carcaletecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
crwdns2931287:025crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If your device turns on but the screen is black or if you when take a picture it comes out distorted or blurry, you may need to change the main board. A bad main board can also cause distorted sound or no sound at all.
crwdns2944105:0crwdne2944105:0
  1. Samsung NX500 Main board  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Main board  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Main board  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out battery.
  4. Samsung NX500 Main board  Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement, Screen Side Encasement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Main board  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Main board  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Main board  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
  8. Samsung NX500 Main board  Replacement, Main board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement, Main board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement, Main board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
    • Use your fingers to disconnect the cable.
    • There are five ZIF cables total to be removed.
  9. Samsung NX500 Main board  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
    • Disconnect the cable using your finger.
  10. Samsung NX500 Main board  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the ZIF cable at the bottom of the main board.
    • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
    • Be careful not tug too hard on the cable as you can damage it.
  11. Samsung NX500 Main board  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the skinny ZIF cable on the left side of the main board.
  12. Samsung NX500 Main board  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX500 Main board  Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the black cable connected at the top right of the main board.
    • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
    • It will easily pop up.
  13. Samsung NX500 Main board  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
    • Lift the board out of the casing and carefully put it somewhere safe.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Eli Carcalete
crwdns2935283:009/15/16crwdne2935283:0
575 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 18-5, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 18-5, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S18G5
crwdns2947412:05crwdne2947412:0
How do you actually get the mainboard for replacement? Is it directly through Samsung?
Andrew Bydlon - crwdns2934203:0crwdne2934203:0
Nevermind, the parts are available at Samsungparts.com.
I believe the particular part of interest is the AD92-02282A, although I'll write a followup if this is not correct.
Andrew Bydlon -
I can now confirm the part is the AD92-02282A. Following this guide worked very well and saved me risking $800 on ebay for a used nx500.
Andrew Bydlon -
i’ve been told that after replacing the mainboard the camera needs to be adjusted which could only be done by a professional workshop.
did you run into any problems with the new mainboard?
Christoph Bresch - crwdns2934203:0crwdne2934203:0
Where to get or address to obtain or purchase new board for replacement?
Bay publicity & Multimedia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,655
