Samsung NX2000 LCD Replacement
  1. Samsung NX2000 LCD Replacement, LCD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
  2. Samsung NX2000 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  3. Samsung NX2000 LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
  4. Samsung NX2000 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the LCD half compartment of the camera from the main body.
  5. Samsung NX2000 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1mm screws with the Y0 screwdriver.
  6. Samsung NX2000 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  7. Samsung NX2000 LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NX2000 LCD Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
  8. Samsung NX2000 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD screen is now separated form the main frame.
Maria Zamora
crwdns2935283:002/09/16crwdne2935283:0
155 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-4, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 7-4, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S7G4
crwdns2942667:0crwdne2942667:0 1,091
