Samsung NP700Z5AH Display Replacement
  1. Samsung NP700Z5AH Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  7. Samsung NP700Z5AH Display Replacement, Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP700Z5AH Display Replacement, Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
    • After they are disconnected, un-thread the coaxial connectors from around the fan.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors "snap" into their sockets much like the metal snaps on a jacket.
  8. Samsung NP700Z5AH Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips#00, remove the single 3.5mm screw from the wireless card.
    • Grasp the edges of the wireless card with your fingers and pull straight backwards to remove it.
  9. Samsung NP700Z5AH Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips#00, remove the six 4.5mm screws from the corner brackets holding the display to the inner case.
  10. Samsung NP700Z5AH Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP700Z5AH Display Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, grasp the edges of the inner case then lift and pull away to separate it from the display.
Erik
crwdns2935283:009/27/17crwdne2935283:0
871 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Carnegie Fall 2017 crwdns2935289:0Eastern Washington University, Team S1-G1, Carnegie Fall 2017crwdne2935289:0
EWU-CARNEGIE-F17S1G1
crwdns2942667:0crwdne2942667:0 1,005
