Samsung NP540U3C-A02UB Battery Replacement
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop.
Alejandro
crwdns2935283:003/28/22crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team C-1, Gurgel Spring 2022 crwdns2935289:0UMass Dartmouth, Team C-1, Gurgel Spring 2022crwdne2935289:0
UMASSD-GURGEL-S22SCG1
crwdns2942667:0crwdne2942667:0 1,434
