Samsung NP510R5E-A01UB Cooling Fan Replacement
  1. Samsung NP510R5E-A01UB Cooling Fan Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
  2. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet that have arrows pointing towards them. The rubber feet are very sticky so use the metal spudger to pry them up.
  3. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the JIS #0 screwdriver, remove all the screws in the back case.
    • Unscrew the 9 black 6.5mm screws.
    • Unscrew the 4 silver 4.4mm screws.
  4. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, insert it between the back case and the laptop. Pry up on the back case until the case pops up. Work the spudger all the way around the back case until the back case will lift off freely.
  5. Samsung NP510R5E-A01UB Cooling Fan Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  6. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
  7. Samsung NP510R5E-A01UB Cooling Fan Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the fan cord.
  8. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the two 3.0mm screws.
    • Loosen the four spring loaded screws using the Phillips #0 screwdriver. These do NOT come out.
  9. Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP510R5E-A01UB Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the five 3.0mm screws.
    • Remove the fan from the copper plate.
Jared Thomas
crwdns2935283:003/25/19crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G2, Henning Spring 2019 crwdns2935289:0IUPUI, Team S2-G2, Henning Spring 2019crwdne2935289:0
IUPUI-HENNING-S19S2G2
didn't put anything about reapplying thermal paste?
mortis mortis - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 343
