Samsung NP300E5C Optical Drive Replacement
  1. Samsung NP300E5C Optical Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP300E5C Optical Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP300E5C Optical Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
  4. Samsung NP300E5C Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP300E5C Optical Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the 4 mm Phillips #8 screw removed, firmly but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  5. Samsung NP300E5C Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm Phillips #8 screw to the left of the hard drive using a Phillips #00 screwdriver.
  6. Samsung NP300E5C Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP300E5C Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingernail or spudger to gently pull your optical drive out.
aliahsan95
crwdns2935283:009/23/15crwdne2935283:0
937 crwdns2915208:0crwdne2915208:0
Baylor, Team 10-13, Williams Fall 2015 crwdns2935289:0Baylor, Team 10-13, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S10G13
Great video, simple steps to follow, very good, thanks.
Chris Hughes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,301
