If you find that your laptop dies unexpectedly, or does not charge, a battery replacement may be in order. This guide will help you replace your current battery with a new one.
Lay laptop down so that the bottom is facing the sky.
Push both tabs away from the center of the device.
While both are in the fully unlocked position, slide the battery out.
