Samsung NP-QX411L Hard Drive Replacement
  1. Samsung NP-QX411L Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-QX411L Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
  2. Samsung NP-QX411L Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-QX411L Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
  3. Samsung NP-QX411L Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
  4. Samsung NP-QX411L Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
Rebecca Johnson
crwdns2935283:002/17/17crwdne2935283:0
594 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S19-G3, Hoffman Spring 2017 crwdns2935289:0USF Tampa, Team S19-G3, Hoffman Spring 2017crwdne2935289:0
USFT-HOFFMAN-S17S19G3
crwdns2942667:0crwdne2942667:0 1,881
