Samsung NP-NC10-KA02US RAM Replacement
  1. Samsung NP-NC10-KA02US RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-NC10-KA02US RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US RAM Replacement, Back Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US RAM Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-NC10-KA02US RAM Replacement, Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You are now able to carefully detach the fan from the base.
    Hello.
    Your explanation is right and clear, except you omit to indicate that, when removing the fan, we remove the radiator and break the thermal paste, then it should be replaced, cleaning the two chips (proc and bridge) and the radiator to apply a new fresh thermal paste.
    Pierre Le Fier - crwdns2934203:0crwdne2934203:0
  10. Samsung NP-NC10-KA02US RAM Replacement, RAM: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After detaching the fan, you are now able to remove the RAM by extending the two side bars out
    • During this process, the computer needs to be shut off. Other components could be damaged and the computer would not be able to recognize the RAM properly.
  11. Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung NP-NC10-KA02US RAM Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the bars extended, you are now able to slide the RAM off the base.
JHOAN USECHE
crwdns2935283:010/03/16crwdne2935283:0
372 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 1-1, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S1G1
There is a small lid with one screw for RAM replacement. No need to remove all the bottom part.
D Akimov - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 482
