In order to maximize the memory RAM on a computer, it needs to be replaced with a new one.
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the tab on the left side of the device's battery.
Push the left tab to the right.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
Using two plastic opening tools remove the back plate.
The back plate is now removed exposing all of the hardware components.
Remove the three screws holding the fan using a 3.9mm screwdriver.
Unplug the wires connected to the fan using a plastic opening tool.
You are now able to carefully detach the fan from the base.
Hello.
Your explanation is right and clear, except you omit to indicate that, when removing the fan, we remove the radiator and break the thermal paste, then it should be replaced, cleaning the two chips (proc and bridge) and the radiator to apply a new fresh thermal paste.
After detaching the fan, you are now able to remove the RAM by extending the two side bars out
With the bars extended, you are now able to slide the RAM off the base.
There is a small lid with one screw for RAM replacement. No need to remove all the bottom part.
