Samsung NP-N102S-B05PH Hard Drive Replacement
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung NP-N102S-B05PH Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Daniel Rudzik
crwdns2935283:010/04/16crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-4, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 2-4, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S2G4
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,826
