Slide the lock towards the middle of the camera, in the same direction of the arrow.
Push the blue battery holder up in the direction of the arrow.
Pull the battery out of the battery slot.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the four rubber screw covers.
Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
Remove the back casing by just carefully pulling the casing off of the camera.
Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
Use plastic opening tool to disconnect screen connector from the control board.
Remove the 2.381 mm screw with a Phillips #00 screwdriver.
Use the plastic opening tool to remove the silver metal lens cover.
Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
From the front of the camera, push the lens through the back of the camer.a
Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
Remove the lens assembly from the camera.
