Samsung MV900F Flash Bulb Assembly Replacement
  1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Flash Bulb Assembly Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung MV900F Flash Bulb Assembly Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old screen.
  10. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lens assembly from the camera.
  16. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
  17. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to pull copper connector from the control board.
  18. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
  19. Samsung MV900F Flash Bulb Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
Justin Smith
crwdns2935283:003/03/15crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 13-2, Blackburne Winter 2015 crwdns2935289:0Sam Houston State, Team 13-2, Blackburne Winter 2015crwdne2935289:0
SHSU-BLACKBURNE-W15S13G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 395
