Samsung ML2510 Side Cooling Fan Replacement
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
bbaustin
crwdns2935283:010/12/11crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-18, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-18, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G18
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 2,859
