Samsung ML2510 Rear Cooling Fan Replacement
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Rear Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Rear Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Rear Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung ML2510 Rear Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  5. Samsung ML2510 Rear Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
bbaustin
crwdns2935283:010/12/11crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-18, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-18, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G18
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,498
