Samsung LNT4669FX-XAA TV Power Supply Board Replacement
    • Be sure to unplug the TV from the main wall outlet.
    • Carefully lay the TV screen down on a clean flat table with the back side facing you.
    • Using a #3 Phillips head screwdriver, remove the screws holding the back cover on.
    • Thoroughly clean the cover and boards using a damp towel (I like to use 91% isopropyl alcohol) and if heavily soiled use a vacuum with a brush.
    • Using the #3 Phillips head screwdriver, remove the screws holding the power supply board on.
    • Unplug the connectors connected to the board setting aside and carefully noting placement for later connection to the new board.
    • Insert the new power supply board into the location where the old board was located.
    • Follow the previous steps to connect the cables and screw in the screws.
    • Follow the first step in reverse to install the back cover.
    • Plug the power cord into a wall outlet and power on the TV to verify performance.
You can also repair your Power Supply Board potentially by using the BN44-00166C repair kit.
See the Attached Documents schematic for further Power Supply Board details.
crwdns2935103:0crwdne2935103:0
James Finch
crwdns2935283:010/14/17crwdne2935283:0
2.393 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
should we use the same power supply brand/type?
A Shahyadi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 119
crwdns2942667:0crwdne2942667:0 11,423
