Samsung L100 Setting Knob Spring
  1. Samsung L100 Setting Knob Spring, Removing Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring, Removing Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring, Removing Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 Setting Knob Spring: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 Setting Knob Spring: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 Setting Knob Spring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 Setting Knob Spring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 Setting Knob Spring, Flash Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  7. Samsung L100 Setting Knob Spring: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  8. Samsung L100 Setting Knob Spring: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  9. Samsung L100 Setting Knob Spring: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  10. Samsung L100 Setting Knob Spring: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
  11. Samsung L100 Setting Knob Spring, Setting Knob Spring: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Face the bottom of the Flash Circuit board towards you.
    • Remove the one screw that's located on the left side of the lens.
  12. Samsung L100 Setting Knob Spring: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the flash circuit board and turn it over.
    • Remove the plastic setting knob.
    • Make sure to keep copper spring inside of the slot.
  13. Samsung L100 Setting Knob Spring: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung L100 Setting Knob Spring: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take out and replace the Setting Knob Spring with tweezers.
andyhe
crwdns2935283:004/15/10crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-17, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 6-17, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S6G17
crwdns2942667:0crwdne2942667:0 3,159
