How-to-guide for replacing the Samsung Juke SCH-u470 camera/speaker.
Press and hold down the button on the bottom side of the phone with your finger.
While holding the button down, remove the back cover of the phone.
Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
Use the iFixit opening tool to remove the camera/speaker from the motherboard.
Use the iFixit opening tool to gently pry the camera/speaker off.
Hey! Thank you for posting such an in-depth guide to repair and replacement for this phone!! I just recently booted mine back up again, and it's truly been a time capsule of what life was like back then. Everything has been running pretty smoothly up until I tested my speakers. Weirdly, it plays the start up/shut down sounds perfectly, but won't play any other sounds/songs even with the volume all the way up. Camera works just fine, so wondering if you have any suggestions outside of replacement? I still have to find an aux cord that fits to see if sound can come out of there; will keep y'all posted on that. Otherwise, I really appreciate any feedback y'all may have. Thanks again for the guidance!
Update: Found an aux cord that fits, it still doesn't emit any sound. I noticed how the aux cord doesn't feel fully secure on the inside, it kinda jiggles around. Let me know if there's any internal fixes I can try for this. Much appreciated <3
