Samsung Instinct LCD screen Replacement
  1. Samsung Instinct LCD screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct LCD screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct LCD screen Replacement, Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct LCD screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Instinct LCD screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct LCD screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the casing off of the phone.
  6. Samsung Instinct LCD screen Replacement, Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the screws removed, locate the antenna.
  7. Samsung Instinct LCD screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct LCD screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct LCD screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct LCD screen Replacement, Front Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct LCD screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Instinct LCD screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Instinct LCD screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct LCD screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct LCD screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Instinct LCD screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct LCD screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct LCD screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct LCD screen Replacement, LCD screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opener tool, detach the ribbon located on the bottom of the phone below the battery compartment.
  17. Samsung Instinct LCD screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the microchip (located at the bottom of the phone) and insert the plastic opener tool under the screen.
    • Lift up the screen. The microchip is attached to the screen and will be lifted out with the screen.
  18. Samsung Instinct LCD screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After lifting out the LCD screen, the screen and its housing should be separated as shown.
Patrick
crwdns2935283:010/11/11crwdne2935283:0
75 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-13, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-13, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G13
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,655
