Samsung Instinct Antenna Replacement
crwdns2869540:0crwdne2869540:0: 1424
0
5
40
1,424
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
This guide shows how to take out the antenna so that a replacement can be installed.
    1. Samsung Instinct Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
    2. Samsung Instinct Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Holding the phone firmly, use the notches to grip and lift up the battery.
    1. Samsung Instinct Antenna Replacement, Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4.45mm screws at the corners of the phone.
    2. Samsung Instinct Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Instinct Antenna Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
    3. Samsung Instinct Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the casing off of the phone.
    1. Samsung Instinct Antenna Replacement, Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the screws removed, locate the antenna.
    2. Samsung Instinct Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    3. Samsung Instinct Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    4. Samsung Instinct Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift up on the antenna and remove it from the back of the device.
Jimmy Kuo
crwdns2935283:010/10/11crwdne2935283:0
14 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-13, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-13, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G13
crwdns2935297:096crwdne2935297:0
crwdns2959996:0crwdne2959996:0 1,424
