Samsung Impression Keyboard Replacement
crwdns2869540:0crwdne2869540:0: 2.9K
3
20
92
2,934
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
How to remove & replace the phone's keyboard.
    1. Samsung Impression Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
    2. Samsung Impression Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
    1. Samsung Impression Keyboard Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    2. Samsung Impression Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
    1. Samsung Impression Keyboard Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    2. Samsung Impression Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently tug the black and blue ribbon upwards to release the circuit board.
    1. Samsung Impression Keyboard Replacement, Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Keyboard Replacement, Antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
      • The antenna assembly will snap off.
    1. Samsung Impression Keyboard Replacement, Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
    2. Samsung Impression Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
    3. Samsung Impression Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The silver piece you are left with is the physical keyboard assembly.
Ross McKelvie
crwdns2935283:004/18/11crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-10, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-10, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G10
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 2,934
