Samsung Impression Digitizer or Front Buttons Replacement
  1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  6. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently tug the black and blue ribbon upwards to release the circuit board.
  7. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
  8. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
    • The keys will peel right out of the screen side of the phone.
  9. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The silver piece you are left with is the physical keyboard assembly.
  10. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
    • The keyboard slider frame will come off and the flex cable exposed, but not free.
  11. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 outer screws.
    • The screws are 3.5mm in length.
  12. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the phone apart, and remove a 5th screw (3.5 mm).
    • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
    • The device will now be in two pieces
  13. Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the tab underneath the blue tape and gently pull the flex cable.
    • The flex cable will now be completely free.
  14. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw.
    • This screw is 2.25 mm in length.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
  15. Samsung Impression Digitizer or Front Buttons Replacement, LCD: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Digitizer or Front Buttons Replacement, LCD: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
  16. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If replacing the front buttons, remove the assembly at the bottom of the front panel
    • The digitizer is now free to be pulled out from the front housing.
Saul Villatoro
crwdns2935283:004/25/11crwdne2935283:0
255 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-10, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-10, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G10
crwdns2935297:022crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 6,881
