Samsung Impression Circuit Board Replacement
  1. Samsung Impression Circuit Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Circuit Board Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Circuit Board Replacement, Back Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
  6. Samsung Impression Circuit Board Replacement, Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  7. Samsung Impression Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently tug the black and blue ribbon upwards to release the circuit board.
To reassemble the device, carefully follow these instructions in reverse order. With a new circuit board installed, your phone should be functional again! For more guides on Samsung Impression maintenance, visit www.ifixit.com.
Ross McKelvie
crwdns2935283:004/18/11crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-10, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-10, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G10
crwdns2935297:023crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,947
