Samsung Impression Back Speaker Replacement
crwdns2869540:0crwdne2869540:0: 2.7K
4
26
88
2,674
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 20 - 35 crwdns2931279:0crwdne2931279:0
How to remove & replace the phone's back speaker.
    1. Samsung Impression Back Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
    2. Samsung Impression Back Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Impression Back Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
    1. Samsung Impression Back Speaker Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    2. Samsung Impression Back Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
    1. Samsung Impression Back Speaker Replacement, Back Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry the back speaker upwards with a spudger.
      • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
      • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
Ross McKelvie
crwdns2935283:004/18/11crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-10, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 8-10, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S8G10
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 2,674
