Samsung HMX-W300 Rear Case Replacement
  1. Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Rear Case Replacement, Remove tape.: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Remove tape.: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Remove tape.: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  7. Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Rear Case Replacement, Remove scerws.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Remove scerws.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Samsung HMX-W300 Rear Case Replacement, Remove screws.: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Remove screws.: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Remove screws.: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Samsung HMX-W300 Rear Case Replacement, Pry screen.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement, Pry screen.: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the end of the screen with the plastic opening tool.
  13. Samsung HMX-W300 Rear Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-W300 Rear Case Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
  14. Samsung HMX-W300 Rear Case Replacement, Repalce rear case: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Removal of the rear case is completed.
Robert
crwdns2935283:001/21/15crwdne2935283:0
966 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-2, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 9-2, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S9G2
crwdns2942667:0crwdne2942667:0 367
