Demonstrates how to replace the rear case of the camera through instructive pictures and words. Replacement of rear case requires the removal of the motherboard and LCD screen.
To remove the wristband of the device, grab the middle loop and pull the band through.
Remove four screws with a Hex 1.5 mm screwdriver.
Open the HDMI door on the side of the camera.
Remove the single screw using a Phillips #00 screwdriver.
Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull the wire ribbon out with a pair of tweezers.
Use tweezers to remove the tape.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Pry the motherboard up using the plastic opening tool.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Use Phillips size 00 and remove the 3 screws as shown.
Pry the end of the screen with the plastic opening tool.
Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
Removal of the rear case is completed.
