Before replacing the lens, make sure to open the lens cover (use the switch on the side of the lens) for a better look at the scratched or dirty lens. If you suspect the lens is just dusty and in need of cleaning, replacing the lens is not necessary.
            Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
            Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
            Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
            Firmly grip and pull the front casing on the lens to remove it.
            Remove the three 5 mm screws surrounding the lens.
