Before replacing, check to see if the battery is fully charged. Make sure the replacement battery is the correct model. The battery should be a BP 125A Rechargeable Li-ion Battery.
Locate the battery slot on the underside of the camcorder.
Locate the arrow marked on the battery slot door and push in the direction the arrow points to open the latch.
Release the latch and allow it to fully open.
Insert the battery following the diagram marked on the edge of the battery slot.
