Samsung HMX-F90 Strap Side Outer Casing Replacement
  1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Side Outer Casing Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With both hands, pull the side strap apart from the rest of the camcorder.
Amir Harb
crwdns2935283:009/26/17crwdne2935283:0
705 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G1, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S13-G1, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S13G1
crwdns2942667:0crwdne2942667:0 399
