Samsung HMX-F90 Strap Replacement
  1. Samsung HMX-F90 Strap Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Strap Replacement, Hand Strap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement, Hand Strap: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement, Hand Strap: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unfasten the strap from the outside.
    • Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
    • The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
  7. Samsung HMX-F90 Strap Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung HMX-F90 Strap Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the inside of the opened case, locate the silver metal plate and remove the 3mm Phillips screw.
    • Feed the strap through the hole to remove completely so that it can be replaced or cleaned.
Amir Harb
crwdns2935283:009/26/17crwdne2935283:0
705 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G1, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S13-G1, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S13G1
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 459
