Samsung Glyde Keyboard Replacement
crwdns2869540:0crwdne2869540:0: 1,8 тыс.
2
17
82
1 790
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:025crwdne2931287:0
This guide will provide a step by step procedure for installing the keyboard.
    1. Samsung Glyde Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Make sure the device is completely turned off before the repair. The battery should not be removed while the phone is on.
      • Using your thumb, press down and slide the back cover away from the camera.
    2. Samsung Glyde Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    1. Samsung Glyde Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the six 4mm screws.
    2. Samsung Glyde Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
      • Take the case off with your fingers
    3. Samsung Glyde Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The green film is located above the camera. It is the camera connector to the motherboard.
      • Disconnect the camera connector with the plastic opening tool.
    4. Samsung Glyde Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Take a close up of the picture for this step for a better view.
      • Use a plastic opening tool to disconnect the keyboard connector.
    5. Samsung Glyde Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The motherboard is held in place by the circular connector.
      • Using a plastic opening tool, disconnect the circular connector.
    6. Samsung Glyde Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • A LCD connector is located underneath the motherboard.
      • Lift the far edge of the motherboard gently upwards toward the center.
      • Using a plastic opening tool, disconnect the LCD connector.
    7. Samsung Glyde Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the motherboard up with your fingers.
      • Place the motherboard in a secure area.
    8. Samsung Glyde Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
      • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
      • With your hands finish prying apart the antenna by lifting it up.
    9. Samsung Glyde Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Keyboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
Cameron Law
crwdns2935283:010/12/11crwdne2935283:0
142 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-12, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-12, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G12
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 82
crwdns2959996:0crwdne2959996:0 1,790
