Samsung Glyde Camera Replacement
crwdns2869540:0crwdne2869540:0: 1.5K
2
22
87
1,529
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
This replacement can be done to restore a phone's camera functionality. By fixing this, this can solve blurry or broken camera or problems focusing. No skills are required for this replacement besides having minimal strength. Be aware that the camera is difficult to access and is also attached with adhesive, making it difficult to remove. Be sure you know that this replacement is permanent. Some tools you need are the iFixit Opening Tool and the Philips #00 Screwdriver.
    1. Samsung Glyde Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Make sure the device is completely turned off before the repair. The battery should not be removed while the phone is on.
      • Using your thumb, press down and slide the back cover away from the camera.
    2. Samsung Glyde Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    1. Samsung Glyde Camera Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
    2. Samsung Glyde Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
      • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
      • Using your fingers, take the case off.
    3. Samsung Glyde Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The green film above the camera is the camera connector to the motherboard.
      • Use a plastic opening tool to disconnect the camera connector.
    4. Samsung Glyde Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The golden film connector connects the keyboard to the motherboard.
      • Use a plastic opening tool to disconnect the keyboard connector.
    5. Samsung Glyde Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The circular connector holds the motherboard in place.
      • Using a plastic opening tool, disconnect the circular connector.
    6. Samsung Glyde Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • There is a LCD connector underneath the motherboard.
      • Gently lift the far edge of the motherboard upwards toward the center of the phone.
      • Using a plastic opening tool, disconnect the LCD connector.
    7. Samsung Glyde Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
      • Place the motherboard in a secure area.
    1. Samsung Glyde Camera Replacement, Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Glyde Camera Replacement, Camera: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your thumb and index finger to grip the camera connector.
      • Pull the camera connector upwards to detach the camera.
      • The camera was glued on, so this may require moderate strength.
Cameron Law
crwdns2935283:010/12/11crwdne2935283:0
142 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-12, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-12, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G12
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 1,529
