Samsung Gear VR With Controller Lens Replacement
crwdns2869540:0crwdne2869540:0: 1.4K
2
12
55
1,444
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:030crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
If the lenses on your Samsung Gear VR with Controller are blurry, scratched, or damaged, use this guide to replace one or both of your lenses. For this guide, you will need a plastic opening tool, metal spudger, and Phillips #000 screwdriver head.
    1. Samsung Gear VR With Controller Lens Replacement, Inner Mask: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement, Inner Mask: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement, Inner Mask: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the switch on the right-hand side of the device to separate the cover from the main body.
      • Pull the cover away from the main device.
    2. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four corner screw covers with a metal spudger.
      • The screw covers fly off when removed, so make sure to keep track of them.
    3. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a metal spudger to remove the screw cover centered at the top.
    4. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
      • Lift the front phone mount up and to the left.
      • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
    5. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
      • Pull the plate away from the motherboard gently.
    6. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
      • You can now completely remove the front phone mount from the headset.
    7. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
      • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
      • The largest pop connector may require more effort to remove.
      • Make sure that nothing is connected to the motherboard before you pull it out.
    8. Samsung Gear VR With Controller Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the eight 5mm Phillips #000 screws on the inner mask.
      • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
    1. Samsung Gear VR With Controller Lens Replacement, Lens: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear VR With Controller Lens Replacement, Lens: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the metal spudger to press on the three tabs around each of the sockets.
      • Press the tabs gently to prevent damaging them.
      • Pull out the lenses with your fingers to remove them from the mask.
Jake Criscione
crwdns2935283:001/24/19crwdne2935283:0
587 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G3, White Winter 2019 crwdns2935289:0Cal Poly, Team S18-G3, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S18G3
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 55
crwdns2959996:0crwdne2959996:0 1,444
