crwdns2959928:0crwdne2959928:0 ↓The Samsung Gear VR supports Micro USB and USB-C ports. If your mobile device is unable to physically connect to the headset ensure that the adapter is the appropriate shape for your device's port. This guide will instruct you how to change which adapter is connected to the headset if needed.
Remove front cover from headset.
Slide the latch to the right to unlock the current connector.
Lift connector clip away from headset and towards you.
Slide current connector out and away from headset until it is disconnected from connector clip.
Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
Slide the lock latch to the left to secure the connector into place.
crwdns2947412:05crwdne2947412:0
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Were do I get the USB c adapter
helenpaul77 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I get micro USB converter for gear vr not type c
