Samsung Gear VR Motherboard Replacement
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear VR  Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
David Forlano
crwdns2935283:009/25/17crwdne2935283:0
119 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S4-G6, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S4-G6, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S4G6
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,738
