Samsung Gear S3 Frontier Battery Replacement
  1. Samsung Gear S3 Frontier Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the watch screen-down so that its back cover is showing.
  2. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step will ruin the water-proof seal.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
  4. Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement, Front Screen Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  5. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the motherboard and front screen assembly using a spudger.
  6. Samsung Gear S3 Frontier Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a JIS #00 screwdriver, remove the two 4.5 mm screws.
  7. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery ribbon cable from bracket.
    • Be careful with the battery ribbon cable and motherboard cable (located on the side opposite the battery cable, highlighted with the orange box), as they are very easy to break (ours did when disassembling).
    • Note how the end of the ribbon cable seats in the plastic chassis. Look for the plastic pin on the chassis when re-seating during re-assembly.
    • Separate the chassis from the motherboard.
  8. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the battery from the motherboard.
    • The battery and the motherboard are secured with adhesive; some force is needed.
    • Lithium-ion batteries are potentially dangerous. Handle with extreme care and do not puncture the battery.
  9. Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Gear S3 Frontier Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
    • When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
    • To widen the hole, use the Pro Tech Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
    • Follow steps 8-1 in reverse order to reassmble.
crwdns2935229:0139crwdne2935229:0
William Hurty
crwdns2935283:010/08/18crwdne2935283:0
2,807 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G2, White Fall 2018 crwdns2935289:0Cal Poly, Team S15-G2, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S15G2
crwdns2935297:034crwdne2935297:0
crwdns2947412:048crwdne2947412:0
Is there a way to reseal the watch making it water proof?
David R - crwdns2934203:0crwdne2934203:0
If the seal was damaged during opening the backcover, unfortunately you need a new backcover, cause the seal is integrated in the case.
Frank Mauderer -
https://www.amazon.com/Tesurty-Replaceme...
I bought mine from Amazon. Just replaced the battery after all the tool kit came in. It works like brand new!
Jae Shim -
is there a kit somewhere for the battery/new seal
Adam Seidlitz - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 47
crwdns2936753:07crwdne2936753:0 282
crwdns2936753:030crwdne2936753:0 773
crwdns2942667:0crwdne2942667:0 161,857
