Have your applications or watch become unresponsive? Replacing the motherboard may fix these issues.
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Using your finger, push forward on the release while pulling up on the strap.
Repeat the procedure from step 2 for the other strap.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
Using a spudger, pry up the three cables.
Using the flat end of a spudger, pry up the motherboard.
The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
Where do you get the mother board.
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
Do you have a good source for motherboards? Hope it helps that I +30’d you!
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
