This is just a look into the Samsung gear S2.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            You will need a Y 00 screwdriver, a PH 0 screwdriver, a spudger, and some tweezers.
            Detach your bands from the body of the watch.
            Remove the four Y 00 screws.
            Pry between the bottom and top portions of the watch with a spudger in the area marked. Be sure not to insert the spudger more than about 3 mm so as not to damage the internals of the watch.
            Also, there is a seal inside the watch that goes along the perimeter inside the bottom of the casing. Be sure not to damage this, otherwise you lose water resistance.
            Unscrew the two PH 00 screws.
            Gently pry up the three cables with a spudger that I have marked.
            We will now be separating the main board from the watch.
            You will be gently prying up on the main board in the area that the spudger is located in the second picture.
            Only pry in the spot marked in orange. be patient, as this prying will take some time.
            Make sure that the cable marked in green can feed through its gap.
            Here is a look at the button assembly, battery assembly and the main board.
            Finally, we are able to look at the rear of the amoled display.
crwdns2935229:026crwdne2935229:0
crwdns2947412:026crwdne2947412:0
Thank you for a picture of the internals. I'm thinking about "restoring" a Gear S2 classic.
Just updated, sorry about the delay. The guide is now finished.
How do I replace the screen? It seems like it’s glued on.
Hi Austin, tks for making the guide, How to remove the rotating bezel?
This is my own personal watch, so I did not try to remove the bezel. The only way I can think of is by prying up on the bezel from the top. Just be careful as I do not know how or if the bezel is connected to the watch.
